Results 1 to 3 of 3
Thread: Tig Noob
    May 2014
    Default Tig Noob
    Hello all!
    Just bought a 3035 Spool gun for my millermatic 210 and looking for some noobie advice or hints on how to use the spool gun.
    Also would like to know if I can run the same regulator with Argon as I do with the mix for mig welding.
    Mar 2011
    La
    300
    Quote Originally Posted by sideways View Post
    Hello all!
    Yes you can use the same regulator.
    Dynasty 200 DX
    Millermatic 350P
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution dry saw
    40 ton press brake
    Evenheat Heat treat oven
    1x42 / 4x48 belt grinder
    May 2014
