Results 1 to 2 of 2
    May 2014
    Default Spectrum 2050 Plasma Problem
    The air pressure is set at the recommended 70 pounds on the machine. The machine would not work unless the compressor pressure is at 90 pounds. It has been a steady rise. Now the input pressure has to be at least 110 pounds before the machine will work. It seems no setting of pressure on the machine makes any difference. What could be the problem?
    8,325
    Ptobably because your lines have alot of moisture, and the regulator is jammed/corroded
Tags for this Thread
