Page 1 of 8 123456 ... LastLast
Results 1 to 10 of 75
    Default New Here DX 200 HF Arc Start problem
    Very much a beginning welder. Recently purchased a used DX 200. It appears the HF start is not working.
    Goggle tells me that this is a recurring problem. I can hear the points firing but NO arc.
    Can the points be cleaned.....found new board on ebay for $350!
    All setting are correct and Tungsten is sharp and clean.
    Any help here? Is this a re-curing Miller dx 200 problem?
    I will be back with specific ser#.....
    this seems to be the common theme.....
    We have an older dynasty 200 as well. Ours is doing same stuff. Needs new board. We tried adjusting gap and cleaning it but no go. Sucks. Newer ones have different hf starting. No way to upgrade either.
    We wanted a water cooled setup so just got a 280 dx to replace the 200dx.
    just wondering if Miller is a "stand-up" company or not.....
    This welder was not free...and if it is defective.......from the get-go.......?
    Nov 2003
    3,845
    Smile
    There have been a lot of threads on this subject...
    you might read a few of them...
    welder serial#....?? that will tell us the age and build series.. (there have been 23+ iterations of the Dynasty 200DX)
    Did you try it under power before you bought it...??
    surely you checked it out and made sure it was fully operational before laying out the money..??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Wa
    671
    As with any tool, things wear out and break. How many hours and arc starts does the unit have?
    Ser# LF099147
    Stock# 907099-01
    surely I did not....check it out. Dumb on my part. I called the local weld shop (Sidney Lee) and they said for that price buy it! so i did.
    The problem is that I did not know enough at the time to test it.
    Point taken however this appears to be a genuine problem with this unit. I would expect a good company would stand behind it.....especially since their stuff is USA made and expensive.
    I do not mind paying for quality.
    At the end of the day I don't realistically expect much help.
    If the HF start board can be replaced with a new one and I could be assured it will give good service I'd be OK with that. I just don't want to throw a bunch of money at it and have it still not work.
    How do I find this out?
    I just heard back from Miller4less-
    "Good Morning,
    Item #209112 has been superceded new item #230191 3 wk lead time from receipt of purchase $535.69
    Thanks,
    Dawn"
    Is it worth spending $537?
    Nov 2003
    3,845
    Thumbs up
    Quote Originally Posted by scratchedup View Post
    Ser# LF099147
    Stock# 907099-01
    Your Dyn200 is early-mid 2005... pre "Blue Lightning"
    here is the manual..
    http://www.millerwelds.com/om/o2240k_mil.pdf
    In all likelyhood it is not broken..
    earlier machines were a bit finicky about arc starts..
    there have been MANY threads on the subject.. you might search and read them..
    is it throwing error codes??...
    what are your settings..??.. and what are you trying to weld??
    You may want to reset it to factory defaults and try again...
    many times.. too many conflicting settings get entered and the DYN will go into brain freeze... and a reset will clear that.. worth a try..
    We have to remember... this is a 9 year old machine...that may have thousands of hours and arc starts... so anything is possible...
    My Blue Stuff:
    Thanks for the input...
    I have done quite a bit of research ...that is why I'm (Maybe) a little upset with Miller...it seems to be well known that these early machines had HF arc problems. They should own up...I have yet to contact them however.
    I like your idea of a big factory re-set. No codes.
    Mostly the machine sat in the back of a truck....I just don't think it was that used.
    I replaced the whimpy 14ga cord with a 15' 6ga and cleaned up the inside. It was bought used about 3 years ago. I've used it maybe 10 times.
    As far as what I weld...at this point it is just practice on mild steel with a little stainless thrown in. The setting are all the standard of what I'm doing.
    The machine does fine with the welding its just the HF start that I'm having trouble with.
