Thread: XMT304 help 6
    Apr 2012
    Oregon
    37
    Default XMT304 help 6
    I have done a fair amount of testing on this machine. Input voltage is 241 vac, contactors look almost new inside, IGBT's seem ok, lem has power and is not shorted, output diodes not shorted. Anything I should double check before replacing the top PC board? (Anything that would harm a new board)
    Mar 2014
    Texas
    54
    Are the caps balanced?
    8,021
    help 6 ALWAYS means that the top board is toast, so either the unit is not recognizing the input voltage or the pulse transformers are not firing the igbts.
    Apr 2012
    Oregon
    37
    Caps are balanced, but at a reduced voltage because CR1 does not pull in.
    Apr 2012
    Oregon
    37
    Thanks cruizer.
    Apr 2012
    Oregon
    37
    New board installed. Machine works great. Thank you to all who helped.
