Results 1 to 10 of 12
Thread: welding inconel
    Default welding inconel
    What's the by product floating on top of bead when welding inconel??
    Dec 2008
    west central Florida
    141
    Some of the material suppliers offer metallurgy support, contact your supplier and see if they can help. Are you just curious or is there a specific reason you ask?
    May 2014
    Northern AZ
    15
    Quote Originally Posted by thatsallid0 View Post
    Are you using TIG, and are you talking about that stuff that looks like scum or kind of a skin on top if the weld?
    MM 185
    Syncrowave 180 SD
    Spoolmate 3035
    Victor Journeyman Oxy/Acet set
    Life Member D.A.V.
    Jul 2006
    alaska
    182
    There should not be anything floating, I would guess dirt if your tigging it?
    Yeah I'm tigging it. Did a coupon and ground all that **** off for that. Now werkn on pipe to flange and don't wanna grind off that stuff on my cap. Its not attractive junk
    Jul 2006
    alaska
    182
    Clean everything, including the rod, and use clean gloves see if that helps.
    I even tried clean gloves. Have u welded inconel without that junk surfacing? Is that junk guna appear in xray?
    Jul 2006
    alaska
    182
    I have never seen that and yup if you are seeing stuff like that it is not good. The weld should be colorful and pretty.Change your filler, make sure you are using the proper set up, gas, cup, tungsten, etc. Send a pic of said weld.
    Nov 2003
    3,834
    Smile Tig...??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    alabama
    759
    Yeah its normal, I never had an issue with x ray.
    2- XMT's 350 cc/cv
    1- Blue star 185
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
