Results 1 to 7 of 7
    Apr 2014
    6
    Default Passport and Spool Gun
    I have an original Miller Passport purchased in 2005. Can I weld aluminum with it?
    Can I use a spool gun like the Spoolmate 100? Thank you.
    Nov 2003
    3,633
    Quote Originally Posted by KISSOV View Post
    From the spoolgun hookup chart
    "No spoolgun solution available for the Millermatic Passport, must upgrade to the Millermatic Passport Plus."
    http://www.millerwelds.com/products/...gun-chart.html
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Apr 2014
    6
    Thanks for the info, I couldn't find it on the Miller site.
    Feb 2012
    226
    Apr 2014
    6
    So all I have to do is add a switch to switch between the internal spool drive and the external (100) spool drive change to 100% Argon and I'm good to go? Will the 100 spool gun connect to the Passport like the Mig gun connects? Thank you I'm new to all of this.
    Richard
    Feb 2012
    226
    That's what I did with our small 140 mm here at work. Your female control plug only has two pins in it so you need the one with four pins in it.
    If you'll pm me your email I'll send you pictures our i'll post pictures if any one wants.
    I would also contact brwelding they can help you with it.
    Apr 2014
    6
    Thank you I've sent an email to brwelding.
