Results 1 to 10 of 19
Thread: Bad Idea
    Jul 2006
    alaska
    182
    Default Bad Idea
    Hello Gentlemen. I turned this job down because I felt it was a very bad idea because of the forces involved. It is a bracket on an over the cab camper in Alaska for mounting a 5 cubic foot freezer for fish and meat. I guessed he could probably put about 400 lbs of weight on the back of this thing. At first I thought I might do it but that thing hanging out there and our very rough roads made me cancel the job. Here is my initial plan. 1/4" diamond plate, lots of gussets, big hinge, chains helping support. size of bracket 24" long by 29" wide, a lot of air under that, not to mention the hinge and what its bolted to. I think it is something that could eventually break something some where. Let me know your thoughts on this one.
    Mar 2009
    kingsport tn.
    50
    maybe incorporate 2 spring loaded shocks
    Jul 2006
    alaska
    182
    This guy is mad because 1/4" AL isn't cheap enough!
    Dec 2013
    459
    Is there something in his receiver hitch?
    Lodi, CA
    1,315
    Quote Originally Posted by 11b View Post
    So why are you upset???? Sounds like you already turned the job down, time to forget about it and move on.
    Jul 2006
    alaska
    182
    You are correct just trying to get a feel for a "next time thing" Everybody comes up with these ideas and they think you the welder, as an engineer in structural and electrical and holy **** biological physics. I am not that smart, so that is why I ask.
    Dec 2013
    459
    My multi millionaire customer was laying on the BS, but it made me feel good anyway. His pitch was " I'm not all that bright, so I surround myself with people smarter than me. I want you to keep me informed so I'm able to budget, but take ownership of this place. You make the decisions."
    I know he was blowing warm air under my skirt, but in his words was wisdom.
    If we are going to get into engineering, we should learn engineering. Amateur surgeons aren't much in demand for a good reason.
    Dec 2010
    377
    if you welded and fitted for years then you should know a good bit of what will work and what won't work and also how to make the stuff that won't work work.there is always a way to make it you just have to think of past jobs and get it done.
    Aug 2010
    1,182
    Quote Originally Posted by Willie B View Post
    That would be the best solution. Good idea.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Jul 2006
    alaska
    182
    Sure but a well engineered part is "Good enough" a poorly engineered part is overbuilt ,,,,hopefully, or bad case under built. I have not had to many things break but I have seen a lot of things break. Aluminum is also a little different. Were does the part break on an AL welded part? In the actual weld because you took that strength away when you welded it, by about 50%, maybe a little less with different fillers and of course heat treatment and I cant heat treat a camper, that would wreck it.
    Amateur surgeon, like that one!
