Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    May 2014
    12
    Default TB 302 (dc only unit) Help!!
    Hello all,
    I just got my used TB 302 DC only unit. It welds great, on the run idle setting it will "idle up" when I strike the ark and will hold the idle up for a few seconds after I am done welding...... NOw If I plug something into the generator side and the unit is in the idle run setting, it will not kick up and produces low power, but if I manually turn it to the run setting it idles up and I have all the power I need, Any suggestions on where to look for what part is in need of repair
    D
    8,334
    Idle pickup toroid has failed and needs to be replaced
    Dec 2010
    Andover, Ohio
    174
    Welcome to the forum K&D welding.
    May 2014
    12
    Thanks Cruz,
    I will looking in to it,
    May 2014
    12
    Cruz is that the same as a current transducer? Sorry for the slew of questions I am new to fixing. Also finding part numbers seems a bit of a pain, I think the PN is #168829
    thanks again
    8,334
    Yes, CT1
    Aug 2008
    Orange, TX
    1,217
    I suggest you check it before just replacing it. CTs can but rarely fail.
    You haven't offered a unit SN but you should have 0VAC at CT1 leads (PC2 RC11 pins 1 & 3) with no auxiliary load and around 3.6VAC with a 100W light bulb load.
    If CT1 checks out then you've got a PC2 board problem.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    May 2014
    12
    sorry the SN is LH300258Q, I hope its a quick fix, I am ok with just turning it to run and than back to idle run when I don't need full power but I really want the machine to be 100% functional.
    thank again
    Aug 2008
    Orange, TX
    1,217
    Use the values I posted previously to check CT1.
    Also check the harness connectors at PC1 (RC21) and PC2 (RC16) for poor/corroded connections.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    8,334
    You should get 66 ohms on a resistance test
