Results 1 to 7 of 7
    Jan 2014
    Idaho
    6
    Default MM 211 Voltage Conversion?
    Has anyone done the conversion on a millermatic 211 to see what the voltage is at each setting? For example the voltage knob goes from 1-10, but I would like to know what I am actually welding at. Like is a 10 24volts and a 1 14volts?
    Wa
    633
    Search. This topic has been beaten to death. Lots of threads with the info your looking for. Not necessarily a direct answer but it will piece it together.
    8,227
    Get yourself a DC volt meter....
    Jan 2014
    Northern West Virginia
    37
    Default Look at the Owner's Manuel
    I believe there is a graph in the owner's Manuel for the 211 that charts the machine's voltage output at both 120 and 230 volts input. I'm not positive on this but I think the voltage is also partially effected by the wire feed rate too, and of course the numbers for the wire feed rate control are completely arbitrary too.
    Jan 2014
    Idaho
    6
    I will have to keep looking then, I could not find a post after about an hour or so of searching. Thanks anyway.
    2,932
    Wa
    633
    You are not finding it because all of the threads that start the inquiry end up at a dead end when they realize it's not very simple, and above it all, it makes zero difference if you know what the "actual voltage" is rather than "6". In the end if it's set up correctly the welder will run perfect. Makes no difference to know the voltage and wfs.
