    Dec 2013
    439
    Default Sheet metal brake
    As the song goes; "A long long time ago........", I built a sheet metal brake. It works fine, but I can't bend four corners of a box. I want to start over or modify, changing to high clearance and removable fingers or some other way i can fold a box with 10" high sides from 16 gauge aluminum. I now bend two sides, and add two ends. While I love welding time, distortion is a concern.
    Has anybody got a good design?
    found this one, haven't made it yet. Will do 16 gauge full width (approx. 24 inches)
    http://www.woodworkforums.com/f65/ma...rs-home-45792/
    Dec 2013
    439
    Mine (homemade) does 7' 3". At first I thought your link wouldn't help me, then I thought; I have a massive press, most boxes and pans are rectangles, why not a set of dies for the press to do the shorter sides?
    Thanks, you planted the seed for thought.
    good luck. post some pics when you're done, if you can.
    Jun 2013
    PacNorthWest
    68
    Willie, I have the HF 20 ton press with an air/hydraulic jack, been considering this
    http://www.swagoffroad.com/20-TON-Fi...-Kit_p_86.html
    Might be some ideas to "borrow" there... Steve
    Apr 2007
    Eastern Ontario
    101
    Try this thread where I did something similar
    http://mapletrader.com/community/sho...nute-Syrup-Pan
