Results 1 to 2 of 2
    Feb 2013
    16
    Default XMT 304 and RC 12 suitcase voltage has - sign
    The voltage on my wire feeder is reading negative and is not working correctly.
    Polarity is DC electrode +. Checked all wires, no changes made. Controls set correctly.
    Machine threw a HELP 7 code a week ago and then cleared it's self. Was working fine until today.
    Kelly
    8,325
    Busted drain caps don't just clear themselves, All your doing is causing further problems, IGBT's and Caps will destroy themselves, likely you have a baked IGBT right now
