Results 1 to 10 of 12
Thread: Shielding gas
    Apr 2014
    6
    Default Shielding gas
    I'm new to all this so here is a rookie question, how can I tell if the shielding gas is working. I own an original Miller Passport and I've just added an external argon/co2 tank. Thank you.
    If its not working properly or enough flow, you'll have bad porosity.
    May 2010
    Central CA
    783
    If you can hear it comming out the nozzle it's working.
    Make sure the switch is flipped to the EXT tank.
    Those little welders never cease to amaze me.
    It's my go to welder for anything under 5/16''.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Wa
    600
    As bob just said, put the torch up near your ear and pull the trigger, you should hear the gas release in a hiss sorta.
    Or buy one of these. Kinda handy to have around.
    http://www.arc-zone.com/index.php?ma...8br0o4bd2ob6q1
    2,908
    Quote Originally Posted by KISSOV View Post
    make sure ya flip the switch on the inside for the Passport to use the External tank
    I just noticed Bob already said that
    May 2011
    Bossier Parish La.
    550
    And be sure to open the tank valve, too.
    Lodi, CA
    1,293
    And make sure, you don't feed the wire into your ear. That might hurt.
    May 2011
    Bossier Parish La.
    550
    Not if the ground clamp is attached to a bare toe.
    Illinois
    611
    All of the above and backseat tank valve. Open tank valve fully.
