Results 1 to 10 of 13
Thread: Dog Boxes??
    Oct 2005
    Dallas, GA
    5
    Unhappy Dog Boxes??
    Hey Gang,
    Does anyone have plans for building dog boxes? I am looking to build custom boxes for my two search and rescue dogs. Need something fairly light, super durable and able to transport my dogs in safety and comfort 4 seasons out of the year. Plan to use aluminum, but do not have a spool gun. Any plans or reccomendations out there? If I bought a box like this, it would cost about 500.00 each, and I need two of them, and want to be able to customize further, so I figure I should build them myself- - -plus I need a project for this winter! Most are made of diamond plate aluminum, but I have no idea what thickness. Rough dimensions= 36long, 24 wide, 30 tall, with doors, and vents, etc.
    Thanks in advance,
    Stuart Samples
    Dallas, GA
    Millermatic 175 Mig
    Stuart_samples@us.crawco.com
    3,945
    I have looked at a few, just checking them out. I have mini weiner dogs so the glove box works fine for a hauler . Just kidding. One had like 14 ga alum the other had 1/8". You could prob get away with welding them with your Miller but you have to watch the heat on your mig gun. I would go with the 1/8" if you can get a deal on it. You can cut it with a table saw or hand circular saw both with a carbide blade. I don't think they make a Teflon liner for your welder so you will just have to wing it. Maybe someone on this group is closer to you and could weld it...Bob
    Oct 2005
    Dallas, GA
    5
    Default Thanks, and more questions..
    I was thinking about getting a spoolmate 3035 spool gun and the, SGA-100 spool gun adapter to go with my Millermatic 175. Has anyone on this list used this combination successfully to weld aluminum? Are there better options, or is this the best way to go without spending a fortune?
    Thanks for the advice on the thickness, I did a little more research, and most of the manufactures appear to be using .080 thickness, or roughly 1/8 inch, so you are dead on. Thanks again, and any more advice on acutally welding the aluminum is appreciated. never tried it, but I am willing to learn!
    Stuart
    3,945
    Check with the guys over at the Millerwelds Motorsports group, maybe someone has that combo...Bob
    http://www.millermotorsports.com/mboard/
    Appleton, WI
    403
    stusamples,
    The SGA 100 along with the Spoolmate 3035 work very well off the Milermatic 175. 1/8" diamond plate would be no problem capacity wise for this combo.
    Kevin
    Oct 2005
    Dallas, GA
    5
    Default Thanks
    Thanks again for the replies, I will let everyone know how they come out, and will post my shop drawings and pictures as well as I progress!
    Happy welding,
    Stuart
    Appleton, WI
    193
    Default dog boxes
    Stusamples,
    regarding material thickness, 14 gage sheetmetal is about .075" thick and 1/8" material is .125". Thats a pretty significant difference. The lighter material would be fine but you may want to reinforce the corners a bit.
    Oct 2005
    Dallas, GA
    5
    Talking Thickness
    Miller john,
    Thanks for the advise! 14GA is probably what I will use. I found a piece of 1/8 last night, and it is way more than what I need. I want these boxes to be light and easily movable. Here is a picture similar to what I want to create. I may be in over my head, but the dogs won't mind if the first few hundered welds are ugly....
    I am also struggeling with the decision between spending nearly 700$ on a spool gun and controller to mig the aluminum, or just going the distance and paying 1300$ for a miller econotig. I know the differences in the processes, speed vs precision etc, but wonder if anyone has reccomendation either way? I am a hobbiest, by I am always welding stuff, and love to build, and create stuff, so I am not sure which is the best choice. I can stick, mig, tig and torch weld, but I only own a millermatic 175, so not sure which way to go for the money. Decisions, decisions, but any recomendations are appreciated!
    Thanks again for your post,
    Stuart
    To weld aluminum boxes?
    Miller Econotig 903367
    or
    3035 spool gun with spa 100 controller
    Approximate picture attached of what I hope to achieve....
    http://www.doggonepet.com/web-conten...ages/55010.gif
    Fallbrook CA
    20
    Personally I would not get the econo tig even though it will do what you want. For very little more $ you can get a syncrowave 180 SD Much much better welder and will keep you happy for a very long time.
    Check past recommendations and comments on the Hobart welding Forum by Dan and others. Regardless it's your money what ever you do try one before buying one. Demo them (all that you are considering buying) Cheaper in the end to get the right one the first time.
    Harold
    markham texas
    43
    stu, might check into getting as many pieces broke as you can. it'll save you alot of welding and it won't warp as bad,,,as for a machine,,, get bigger than what ya need cause i've seen a lot of folks get just enough and regret it later,,, later,,,outlaw...
