Results 1 to 10 of 16
Hybrid View
    Dec 2013
    At the epicenter of the Green Mountain Range in VT
    395
    Default Trailblazer and Bobcat 250 What's the difference?
    Today at the mill it was much like a bee hive. Maybe thirty people involved in replacing the grinding/drying system. Howard the fabricator had his new Trailblazer 400' away at the shop. Too much traffic jam to move it so we shared my Bobcat 250. He talks of features on the Trailblazer that'll spoil you. Ive never used his Trailblazer. He says it's hard to stick 7018, I could live with that. Lets say his 7018 vertical and overhead welds look better than mine, but about the same with either machine.
    What's the difference in features, I know about the 14 pin connector, and digital read out, but what sets them apart really. I'm sort of a ***** for great tools, especially welders.
    May 2011
    Bossier Parish La.
    559
    I believe one of the features of the Trail Blazer over the BC, is the AC generator is seperate from the welding generator on a common shaft. This way, whatever AC current is being used off of it during welding(like someone using a grinder while another is welding) does not affect the weld output, since they are coming from different sources inside the machine. If you were to be just straight stick welding only from either machine, I don't see where there would be much if any difference between the two. But I have never used a TB so I can't say for sure on that.
    Try welding a few beads with his machine and then a few with yours to see if you can detect any discernable differences with the weld output.
    Dec 2013
    395
    Things are too crazy this week, 9 day shut down to replace equipment. This is a single stream mill. Each ounce of pine pellets passes through each machine. I'm in awe at how many machines are required to grind up a tree, dry it out, and squirt this hot gooey mess through thousands of little holes, break them off, cool them, remove dust, and bag, palatalize, then stockpile. The system always has a bottleneck limiting production. Maybe it won't be as busy next week.
    May 2011
    Bossier Parish La.
    559
    Whatever happened to cut. split and stack your firewood then let it season ?
    Dec 2013
    395
    I tell them it is possible to burn wood with less processing. They don't see the humor. It does make it possible for those convenience seeking environmentalist types to feel they are being "green". I don't think they factor how much energy is used to process.
    May 2011
    Bossier Parish La.
    559
    Quote Originally Posted by Willie B View Post
    Exactly. They think these pellet sacks are just harvested from under the wood pellet trees for their use. Kind of like gathering pecans, except for a "wood" burning stove.
