Thread: die size
    Jan 2013
    19
    Default die size
    I know this isn't a welding question but I can't find the diameter I need to thread for a 14-1 left hand die. Anyone know?
    Dec 2011
    406
    Will this give you the dimension you require?
    http://theoreticalmachinist.com/Thre...dImperial.aspx
    Are you talking about a 14 inch diameter with 1 thread per inch?
    3,928
    13mm would be the drill size...Bob
    http://www.kasthurimmc.com/tap-drill-chart.html
    3,928
    If you are using a die the dia would be 14mm on the shaft...Bob
