Results 1 to 3 of 3
    Nov 2013
    East Texas
    Default Millermatic 210 won't arc
    i CHANGED OUT THE SELECTOR DUE A BURNED OUT CONTACT. PRIOR DO DOING THAT I TURNED IT OVER TO ANOTHER RANGE AND IT WORKED FINE SO i REPLACED THE SELECTOR AND NOW IT WON'T LITE UP. FAN DRIVE ROLLS WORK BUT NO ARC. I NEED TO STAART LOOKING FOR THE PROBLEM AND DON'T WHERE TO START FIRST. I COULD USE SOME HELP ON THIS.
    Mar 2014
    Texas
    54
    Did you replace that switch one wire at a time matching the numbers that are on the back of the switch? Sounds like you wired it wrong.
    8,181
    Well, if it worked and now it doesn't, the above post seems to be your best answer, of wiring it wrong...
Tags for this Thread
