Results 1 to 10 of 12
    Aug 2008
    29
    Default Syncrowave Coolant Pump
    My coolant pump on my Syncrowave 250dx (Tig runner) has failed. It doesn't turn on most of the time, and when it does, it is painfully loud.
    On the pump, it is labeled 'Procon CMP-7400'. All the online resources say that this pump isn't manufactured anymore. None are available on Ebay.
    In the manual, it is labeled as Miller PN 211045. A few online site have the pump in stock, but it is $450+!
    I see Miller changed up their integrated cooler. Is there an alternative motor/pump that won't cost 10% of what the whole welder cost?
    Oct 2004
    Edmonton, Alberta
    8,350
    Still available from Miller, quite a pricey list though, $450 is pretty good in other words.
    What you can do is take it apart, and see if its simply gooey in there. Its the brass bushings that let go
    May 2009
    Central North Carolina
    150
    I've been told that Procon offers re-build kits for their pumps, but I never tried to get one. Before I spent $450 for a new pump I would certainly explore doing a re-build of the one that you have.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF & DIY Cooler
    2 Miller Digital Elite and 3 Fixed Shade Helmets
    2 O/A torch sets
    DeWalt 18 volt 1/2" Driver/Drill
    DeWalt 18 volt 6 1/2" Metal Saw
    DeWalt Porta Band & SWAG Offroad V3 Table
    Milwaukee 8" Dry Cut Saw
    Milwaukee 14" Dry Cut Chop Saw / Delta Stand
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Milwaukee Hole Hawg 1/2" Drill
    Wallace 5 Ton Gantry
    Too many hand tools
    Aug 2010
    Los Angeles
    1,183
    Edco distributing can probably rebuild your pump for you. Halsted and Hogan used to do it but uses Edco now.
    It comes back looking nearly brand new. http://www.edcodistributing.com/pcpumps.php
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Aug 2008
    29
    Quote Originally Posted by shovelon View Post
    Thanks for the info. I contacted them to see if they'll do it.
    Aug 2008
    29
    Quote Originally Posted by jpmassey View Post
    They can't do it. I'll try procon for a kit.
    Nov 2003
    3,731
    Might be barking up the wrong tree... but have you checked to see if you have a clogged intake strainer or a sheared shaft coupler and not a bad pump..??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Nov 2003
    3,731
    Smile
    If you do need a kit or Procon parts...
    I have heard good things about JC Beverage... the contact mentioned was Joe..
    http://jcbeverage.com/
    Hope this helps,,,
    My Blue Stuff:
    Millermatic 200
    Aug 2008
    29
    Quote Originally Posted by H80N View Post
    The shaft coupler is good.
    There is no intake strainer.
    I took the pump housing off and it spun up just fine. However, the vanes seem to be stuck in place. I suppose they need to move back and forth. I wonder if this is jamming the pump?
    Aug 2008
    29
    Cleaned up everything with a solvent. There was a sticky coating over everything. Lubed the vanes and Orings with vaseline and put it back together. Don't get the flowrate error, so it appears to be working fine!
