Results 1 to 8 of 8
Thread: truck rack
    Apr 2006
    TAXACHUSSETTS
    1,495
    Default truck rack
    Another truck rack for a customer.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Oct 2012
    Neosho Mo
    78
    Nice work! Is the rear top cross piece removable for tall items in the bed of truck or solid?
    Apr 2006
    TAXACHUSSETTS
    1,495
    Removable,see the bolts.That tube 1/2-13 threaded.The rear pc can store in front of toolbox behind cab there is 2 threaded angle clips to hold rear pc there when not not needed.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Oct 2008
    southern,colorado
    9
    Thanks for sharing
    Millermatic 210 with spoolgun
    Millermatic 211
    Lincoln Precision Tig 225
    Miller Spectrum 375 plasma cutter
    4x8 CNC Plasma Table with TD Cutmaster 101
    Hydmech DM 8 horizontal bandsaw
    Edwards 40 ton ironworker
    Mk Morse dry cut saw
    Hougen HMD 904 mag drill
    2 Bench grinders
    6 angle grinders
    Slip roll 48 inch
    Pan and box brake 48 inch
    Tubing bender
    etc.,etc.,etc
    Dec 2010
    355
    looks great .nice and sturdy for sure.
    May 2008
    Troy, MI
    351
    Nice job.
    I always enjoy your post and pictures.
    Thanks for taking the time to post.
    Don
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Apr 2006
    TAXACHUSSETTS
    1,495
    Quote Originally Posted by Don52 View Post
    Nice job.
    Don
    Customer just got it back from paint will get a pic when I get a chance.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Jul 2006
    alaska
    182
    Nice, very clean.
