Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: what machine
    Mar 2013
    25
    I was in the LWS and was pricing out the Shopmate and 350. I'm not sure which one, but sounds like I can't go wrong either way.
    Mar 2006
    Corunna Ont, Canada
    455
    Quote Originally Posted by Portable Welder View Post
    Railman, I'm surprised your saying that, On the other hand I have not run the new 252 but I have the XMT set up, a 1987 MM200 and approximately 1996 Miller Vintage 250 amp machine.
    I just find that most of those stand alone MIG's just never seem to have enough power for my hot hand....... Now I have never run a 350P.
    Guess I'm just pushing them too much....
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Nov 2003
    3,508
    Thumbs up
    Quote Originally Posted by Railmen View Post
    Railmen
    If you get a chance...
    Try the MM350P....
    Bet it makes you smile....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  4. #14
    Feb 2013
    Southwestern WV
    96
    I'm gonna put my .02˘ worth in. I replaced my MM 252 with XMT 350 and S74dx feeder. It is leaps and bounds ahead. The 252 is a toy compared to the XMT.
    Syncrowave 350lx
    XMT 350 CC/CV
    S74DX Feeder
    30a spoolgun
    Hypertherm 1000 g3
    Harris O/A
    Cincinnati lathe
    Acer Ultima "Bridgeport Mill"
    340hp Quincy and 400 gallon of air
    Other doodads and a stoker coal stove
  5. #15
    Aug 2004
    Milan Michigan
    1,806
    Apparently I don't weld on big stuff like a lot of you, The largest stuff that I ever get are excavator booms, sticks, and the buckets, sometimes we do some loader buckets also.
    So its very rare for me to weld anything more than about 1-1/4" other than the shanks that hold the teeth.
    My little 250 amp migs like the 252 do a great job on that.
    If any of you find the MM200s or the 250s not being big enough try using lincolns dual shield 71 Elite with .045 wire and 75/25 gas, It will give you additional heat over the hard wire alone.
  6. #16
    Mar 2013
    25
    Thanks for all the input. I ended up getting the 252 and a Syncrowave 210. As I posted, just a hobby welder and it seemed that it would've snowballed into more $ as I would've had to buy tig/stick items, then I might as well get a cooler, therefore a better tig torch and so on.
  7. #17
    Aug 2007
    731
    Quote Originally Posted by concreteguy View Post
    Concreteguy,
    I have a MM 252 and I LOVE it. I am sure you will have no regrets. The only thing I did was put a Bernard gun on it. Good luck.
    Nick
  8. #18
    Mar 2013
    25
    Thanks, I'll most likely upgrade the gun
  9. #19
    Dec 2013
    At the epicenter of the Green Mountain Range in VT
    394
    I have a MM252 it is one sweet machine! It makes me look good! The pellet mill we often work at has its identical twin. When Dale Earnhart Jr was hired as a forklift driver it soon needed a new gun. Purchasing agents bought the cheapest gun they could get. While it gathers dust cause it barely works and then causes more frustration than a computer, everyone finds other ways to fasten. There is a fabricator there today welding 1/4" plate butt welds, hundreds of feet of them using a Bobcat and boxes and boxes of 7018. I asked why he didn't use the 252? He said it's a piece of junk, keeps cutting out. Big mystery, I think someone up for a project could buy it cheap!
