Results 1 to 10 of 11
    Apr 2014
    Grants Pass, OR
    1
    Default MIG trigger is too sensitive for me
    The MIG trigger is too sensitive for me. With gloves on i can actuate the trigger when setting up a weld start point or moving to q new location. This retults in a blast of wire making contact with thing I do not want to weld. Is there a way to increase the pressure required to actuate the trigger?
    Thanks all Skip
    Jun 2009
    greenfield new hampshire
    884
    if we knew what type of rig you have, we may come up with a solution, welcome to the forum
    Dec 2010
    Andover, Ohio
    144
    Welcome to the forum Skip.
    May 2011
    Bossier Parish La.
    560
    Quote Originally Posted by kevin View Post
    That might help a bunch, but one possible way would be to install a stiffer spring behind the trigger.
    Apr 2014
    2
    Default A fix
    Take the handle apart and spread the contacts out with some needle nose. That's how we get a lite trigger pull by bending them closer together . Should fix your problem.
    Jason
    Nov 2003
    3,584
    How can we give you any useful advice if you have not given us the make and model of MIG gun??
    They are all different... some have microswitches.. some have flat brass springs... others yet again different... useless to try and guess till you give us more info..
    MAKE?? MODEL??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Keep your finger off the trigger when you're not welding, hope to **** for the safety of anyone around you you don't own a handgun.
    Mar 2011
    st-eustache qc.canada
    243
    it may be too sensitive or...maybe you are using extra heavy stiff gloves?
    without the model as other said we can feed you infinitely with various suggestions
    Jun 2009
    884
    since we dont know what you have, we could assume that you have one of them 99 buck specials at h f , where the wire is always hot, it is not one of them, i hope
    Oct 2007
    Cave Creek Az
    1,051
    Wear thinner gloves. Those heavy stick arc gloves give you no feel. Look at the tillman mig gloves or something similar.. If you are using a miller mig gum, you can disassemble the red switch, and there is a spring in there. You can pull it apart slightly, but in all the triggers I have had, i have never had a spring issue. Try another similar gun at the LWS to see if it is a lot different than yours, if so, then order a new one. Sometimes dirt will get inside the switch, not allowing it to fully open, might look into that.
