    Jan 2009
    Burnaby, BC
    43
    Default Hooking up a Dynasty 200dx to a Trailblazer 325efi?
    is it possible to hook up a 200dx to a trailblazer 325efi? I thought that the trailblazer had 3phase power but it looks like its 240volt single phase.. ive been looking through my manuals of both of the welders I got, but cant quite figure it out....
    Feb 2013
    North Dakota
    29
    The dynasty 200 can be pretty much hooked up to power known to man
    Wa
    657
    The dynasty can run on anything from 208-575, 1 and 3 phase.
    Dec 2013
    451
    I'm not meaning to hijack. My question is so similar. A Dynasty 280 DX With a Bobcat 250. The Bobcat is rated at 10000? watt. The 280 at full load will exceed that, so no top end. Is the power clean enough that it won't damage the Dynasty?
    TIG is a minimal spatter process, I can use silicone bronze to join galvanized to hot rolled steel or cast. Extremely combustible dust builds up on surfaces in 1/2 hour at the pellet mill. The clean area need not be as large with TIG.
    2,954
    If you have your Dynasty wired up with a Normal 240v 6-50 plug you just need an adapter
    Hobart 770674 Adapter Cord
    http://www.amazon.com/Hobart-770674-...ef=pd_sxp_f_pt
    Dec 2013
    451
    My concern was more about power quality damaging sensitive electronics.
    Nov 2003
    3,690
    Smile
    From my personal experience....
    I have run a Dynasty 200DX countless times off of a Trailblazer 301G...
    and it ran flawlessly with no problems...
    would think the TB 325 would work fine as well...
    But if you have concerns... why not call Appleton and get the official word from the factory..??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Apr 2012
    Western Pa.
    321
    Run my Dynasty all the time off Bobcat 225.
    I've run 1/8 7018 rods with no problem.
    Also ran dynasty off of 4 different generators. One was only 3500 watt but was still able to run 3/32 rod. I've also ran 1/8 6010 & 7018 off 5000 watt generator, pulled all the generator would put out but got the job done. The Dynasty will run off about anything. Never hurt mine.
    Corunna Ont, Canada
    455
    Default Dynasty w/TB302,TB325, Pro300D
    I have done this for countless hours on end....... When I had my TB302 I must have put 100 hours on like that, but here's the catch I was welding with both machines I was running the TB302 around 140 amps 1/8 7018 and the dynasty was running the same.
    Then I bought a Pro300D and did the same thing over and over, even running 5/32 7018 on both machines at the same time.
    Now I just bought a new TB325 about 2 weeks ago and I had a call where I needed to get the job done faster so I tested the TB325 out to make sure I can still do this with no problems............. Yep still can although it seems to work the TB325 a little harder when running 2 5/32 7018 at the same time then I would like to see, so why not try the invision 354MP out on the TB325 and bam it's really nice on the larger rods it don't draw as many amp as the Dynasty on the bigger rod.
    So just for fun, I had the TB325 running as a generator and cranked up the invision to run some 3/16 7018 nice and hot for roll welding on a cap(about 230 amps) and the TB325 barely had to work to make the power for the invision.
    Now if you are wondering why I do this, it's because I get a lot of odd jobs where 2 machine are very beneficial and tough to spend the money on dragging a second machine with me. So when I do need this set-up either the wife come with me or my son, depends on which one wants to make some money.
    Any question, feel free to ask?
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
