    Jan 2013
    Ohio
    57
    Default air cooled vs. water cooled tig machines
    I searched for a thread but didn't have any success...what are the advantages and disadvantages between air cooled and water cooled machines?...thanks in advance
    Aug 2004
    Milan Michigan
    1,828
    Air cooled are more portable, water cooled let you run higher amperage for higher duty cycle times without burning your hands and torch.
    Jan 2013
    Ohio
    57
    Thanks PW
    Dec 2013
    430
    Quote Originally Posted by kerr74 View Post
    Water cooled aren't as bulky, because return flow torch fluid runs in the same hose as torch power, cable can be smaller without overheating.
