Results 1 to 3 of 3
    Aug 2008
    13
    Default Part number for engine wiring harness - TB302?
    Driving to the job site today, I heard my TB-302 cranking. Pulled over and long story short, a squirrel chewed the engine wiring harness almost in half. Right where the harness plugs into the bulkhead connection. I got in at the rear mounting access hole. Made blank covers for the holes today.
    I need the part number for the harness so, I can order a new one. Don't want to splice it.
    Thanks,
    Mike
    Oct 2009
    Northern ND
    17
    Get your serial number and download the correct parts manual.
    http://www.millerwelds.com/service/l...ER%20302%20GAS
    Aug 2008
    Orange, TX
    1,223
    Miller doesn't offer the engine side wiring harness. At least not in their parts break-down. Only the harnesses in the welder/generator.
    Is there enough slack in the wires to allow installing new terminals for the connector?
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
