Results 1 to 3 of 3
    Nov 2009
    Default S32 -P contactor
    I have a S32-P without the contactor. Is it possible to install any off the shelf 250 amp 12v contactor into the machine or is it proprietary Miller.. (They no longer have them avalible the last time I called.)
    If so is it just a matter of finding the 12 v and hooking up terminals on it.. Thanks in advance.
    Mar 2014
    Texas
    54
    Your machine came without the contactor? It's probably the option kit that is no longer available.
    Depending on serial #, both contactors are available and in stock at Miller.
    Aug 2008
    Orange, TX
    1,228
    Yeah the contactor is still available http://miller4less.com/advanced_sear...=10&search.y=5 but the mounting bracket is not.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
Tags for this Thread
