Results 1 to 10 of 13
    Jun 2011
    8
    Default Amperage Dialarc
    Can anyone tell me the idle amperage (amperage when the machine is running but not welding) on a Miller Dialarc 250 AC/DC with power factor corection (PFC) when connected to a 230 VAC power supply? I've ran this maching for many years on only a 40 amp breaker (for 3/32" amd 1/8" 7018 rods only) but last weekend it blew the breaker for the first time when it was idleing. Maybe the breaker is getting weak? Appreciate your comments. Thanks
    Nov 2003
    3,508
    Quote Originally Posted by Niles View Post
    Serial Number..?? for correct manual
    I am seeing about 25amps draw at idle for 230vac... no data on PFC difference..
    See section 3-2 in the manual
    http://www.millerwelds.com/om/o321q_mil.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Nov 2012
    Northern Arizona
    538
    25 at idle!?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Nov 2003
    3,508
    25 at idle!?
    24.8 Idle Amps @ 230 VAC....
    Remember this is a Magnetic Amplifier/Transformer machine...
    and they are power hungry... even at idle...
    My Blue Stuff:
    Mar 2014
    Texas
    54
    PFC will not change the standing amp draw. It's only effective to eliminate spikes when welding. The electric company sees these spikes as useage and bills accordingly. No spikes = lower bills.
    Dec 2011
    418
    Quote Originally Posted by 1997CST View Post
    The literature does not seem to support your hypothesis entirely. From the Dialarc manual of 2004 OM-321 The 250P at idle draws 24.8 amps and the 250 without PFC draws 4.4 amps at idle both on 230v. That looks to me like if you have a 250P you should shut it off when you are not welding. My understanding is that the PFC is really an advantage if you are on commercial power(where you get dinged for being off optimum(1) by more than 10%) and using the machine heavily or if you are using it heavily on residential power where you get billed for the apparent usage rather than the real usage. Someone on the Welding Web forum added a circuit to an ideal arc to disconnect the PFC at idle and only re-engage it when he was welding might be worth a look.---Meltedmetal
    Dec 2013
    394
    Quote Originally Posted by Meltedmetal View Post
    As pfc in a Dialarc runs not from incoming line but from its own coil influenced by or influencing the rest of the transformer, I'm not clear if it is variable in power. If in fact it is full on whenever the welder is on, it might do too much at idle or light load.
    In inductive loads such as a welder, Voltage and Amperage are out of sync. (timing is off). Capacitors are electrical trampolines bouncing back a charge they received in the previous half cycle. Properly sized, they improve the reading from utility meters, at least at full load. Smaller cable is needed, less is lost to voltage loss in service, feeder, and circuit conductors. It may be these machines are over corrected at idle.
    Dec 2013
    394
    If you are tripping breakers under conditions you never did before, I'd suggest getting an electrician to check. could be anywhere between high voltage utility line and welder. A bad connection might cause your symptoms. The place I would check first is behind your breaker. The most common failure is there. Some brands of breaker panels are worse than others.
    Mar 2014
    Texas
    54
    Quote Originally Posted by Willie B View Post
    Great info from both of you. I was only remembering what I had learned about PFC. Commercial gets dinged for the spikes no matter how much you are using or how long the spike is. I'm not sure how that works for residential. Thanks for the info.
    Dec 2013
    394
    My knowledge of electric rates is limited to one power company. Here we have "time of day metering" (a KWH costs more at time of peak load) otherwise a power factor of .9 means 10 percent of the power the utility meter reads is wasted.The same is true of 1.1 or capacitive load. You can overdo it.
    This does not hold true for industrial customers. They pay a penalty when power factor is off.
