Results 1 to 4 of 4
    Apr 2012
    Oregon
    37
    Default WC-3 with Spoolmatic30A
    Is this combination workable? Wiring looks like B to 16, C to 23, D to 22, E to 13, F to 15, G to 21. A to ? D and G could be other way.
    Mar 2014
    Texas
    54
    You need a WC-24 to run a 30A. the WC-3 is 24 AC and the 30A runs on 24 DC.
    Apr 2012
    Oregon
    37
    Could it be converted by adding a bridge rectifier?
    Aug 2008
    Orange, TX
    1,214
    The WC-3 does not have the proper control logic to operate the 30A. You need the WC-24 as 1997CST has stated.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
