Results 1 to 10 of 16
    South Carolina, Dixie
    515
    Angry Snail Trails and Porosity
    All right welders, I am not new to this game. But for the life of me I need to know where all the "snail trails" and occasional but sometimes frequent porosity comes from in dual shield FLUX CORE wire?
    I looked at lack of shielding gas: Nope. 25 cfh
    I looked at wind or air currents: Nope. Inside the shop and no fans.
    I looked at the wire: Nope. Same stuff I've been using.. ESAB 710x.
    I looked at the material. Nope. Even ground off the mill scale.
    I was welding sched. 40 3" pipe to 1/4" flat bar using .045 710x wire at 25.5v and 380 IPM.
    Maybe a couple of you more learned folks can TS this for my old A__!
    Mustangs Forever!
    Miller equipment.
    Nov 2003
    3,584
    Smile
    Glad to see you back...
    thought you were in the Keys...
    Might be a bad roll of wire....
    thought that I had heard ESAB was now marketing Chinese wire....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2009
    Northern ND
    17
    I never go below 40-45 cfh even inside. Don't push dual shield if you can help it, drag it.
    Approx. 3/4" stick out.
    Has the wire been in high humidity for a while? Just some things I've had problems with in the past.
    515
    Cool Relocated
    Had a new opportunity in the Carolinas. Working Marina needed a private welding contractor. Been at it now about a year. Building mostly Anodized aluminum stuff but, like most of us, doing whatever it takes to keep the wolves at bay.
    Really nice to hear from you too!
    Mustangs Forever!
    Miller equipment.
    3,949
    I weld .045 ESAB 710X everyday. Turn your volts to 23.3 and the wire to 233 and try it. You are too hot for the part...Bob
    515
    OK. I'll give it a try. As for the CFH... am I using enough at 25? I know my other 350P machine is set for AL only and I run 45 cfh on the 100 Argon. But I can't ever remember running more than 25 cfh on the 75/25 gas.
    Mustangs Forever!
    Miller equipment.
    3,949
    Quote Originally Posted by captkipp View Post
    I run 25 cfh with 75/25 on my machine. Also i use the M-25 Miller gun and when that rubber O Ring at the end of the nozzle wears out i get holes. Don't know what gun you have but just a thought...Bob
    515
    Angry
    The new mm350p came with the Bernard Q gun. I believe it's to 300 version.
    What's frustrating about it is that the other day I ran 30+ pounds of this 710x wire on a bunch of 1/2" plate projects all in one day using the same settings and had very few issues except for the occasional puff of Mother Natures breath in the shop. Today however, I was just shy of giving it a blue letter cussing.
    Mustangs Forever!
    Miller equipment.
    Are you using the same cylinder as the previous day ? Some have complained about random bad fills.
    1,909
    I have found that when you are over running the wire this happens. To hot, to fast or both. Try turning it down some. Gas should be fine.
