Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Los Angeles
    2,927
    AK- you never mentioned if you actually switched the wires INSIDE the machie
    Remove the sleeving from both leads.
    6. Connect the large lead to push-on terminal
    labeled “3” on the adjacent PC board.
    7. Connect the small lead to terminal 15 of the line
    switch.
    8. Reposition insulation to cover line switch.
    9. Re-install wraparound.
    10. Move the lock pin to allow switch movement for 230 V selection only.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
  2. #22
    Sorry for no update.
    Thanks for the tip Ed.
    I'll check.
    Willie,
    You'll be the second to know.
    ~John
    Life is to short for cheap tools.
  3. #23
  4. #24
  5. #25
    Sorry, double post, but.... I hope you'll forgive me.
    Ed,
    I had so forgotten about the relinking.
    So used to auto links.
    I printed your post off and ran over to the shop (real quick)
    Took maybe 30mins to do it.
    But, she fired right up, after a few bugs worked out, I took her outside hooked up my leads, and made a couple welds.
    ~John
  6. #26
    Made an ok weld.
    These rods had been cold for months. open box.
    Poor helmet, poor gloves, poor stability....
    But what am I complaining about???!!!!
    The welder is running!! Welding!!!
    Thanks guys for putting up with me one more time.
    I have two more welders coming in the mail, I might need help on them
    Thanks,
    Again.
  7. #27
    Default Is this OK???
    What do you think????
    Hows it look???
    My hats off to you guys for putting up with me....
    I really appreciate it.
    Hopefully I can help you guys with something, someday
    ~John
  8. #28
    Nov 2003
    3,519
    Smile
    Glad you got it sorted out...
    so many times IT IS the Simple things that get you...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  9. #29
    Quote Originally Posted by H80N View Post
    Thanks H80N, and a Big Thanks Ed....
    That arc on that buzzard is pretty smooth for 7018, but a little soft for 6010....
    I'm not sure if I'm gonna get a tig torch etc, or just sell it....
    We'll, since me being a 7018 man, fits me....
    ~John
    Hows the slag look on that bead???
    Anyone still content with raking the slag???
  10. #30
    No one likes the slag....
    Back to the drawing board...
    ~John
