Results 11 to 20 of 30
    Aug 2013
    102
    not a 3 phase machine is it?
    Quote Originally Posted by AKweldshop View Post
    Ok guys,
    I bought this machine from a reputable guy on eBay.
    This guy had 8 eight of them. took them out of service, they wired 480v.
    http://www.ebay.com/itm/161246264682...84.m1497.l2649
    I got the machine, was full of dielectric power. normal I guess.
    I put the 6-50p on it.
    Switched the switch on the back to 230.
    Plugged it in, and nothing happens.
    I talked to the seller, I trust him.
    That's beside the point.
    Pics
    Attachment 33969
    Attachment 33970
    Attachment 33971
    Attachment 33972
    Attachment 33973
    Let me know if you need more pics or info.
    Thanks,
    ~John
    Dec 2013
    At the epicenter of the Green Mountain Range in VT
    476
    I can't read the nameplate. Will it configure to 240 Volt single phase? Might it be possible to download a manual? I wonder if the way it is linked for 480 it won't recognize 240 as useable power supply. Most machines have connection diagrams on or in the supply enclosure.
    Nov 2003
    3,846
    Quote Originally Posted by Willie B View Post
    Willie
    I gave him a link to the manual in post #3.....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  4. #14
    Dec 2013
    476
    Quote Originally Posted by H80N View Post
    Willie
    I wasn't able to open the link. The red lead has me wondering.
  5. #15
    Nov 2003
    3,846
    Smile
    Willie
    You may have a point there......
    Easy enough to check which color wires are connected on the WELDER side..
    that machine is single phase only so it may not follow the same convention used on the Miller Dynasty wiring...
    if it is not connected... it will not power up....
    Try this link to the Manual
    http://www.lincolnelectric.com/asset...oln3/im592.pdf
    My Blue Stuff:
    Millermatic 200
  6. #16
    Feb 2012
    226
    Page a-3 tells you how to switch to 230 v in the manual posted.
  7. #17
    Quote Originally Posted by JerseyWelder View Post
    I'm pretty sure its a 1ph machine.
    There was only three wires.
    I'm guessing it was 480v when I got it.
    I put a 230v plug on it.
    H80N,
    Thats the part in the manual I read.
    Makes sense that if I have the plug wired on that the fuse shut off all the power.
    I'll check and get back to you.
    Thanks.
    ~John
  8. #18
    Nov 2003
    3,846
    H80N,
    Thanks.
    ~John
    This is absolutely a SINGLE PHASE machine...
    You might check what color wires connect to where INSIDE the welder...
    Willie might be on to something regarding the red wire..
    My Blue Stuff:
    Millermatic 200
  9. #19
    Sorry to confuse.
    This is single phase machine, designed to run on 230v or 480v.
    This machine came with a 480 plug.
    I took it off and put a 6-50p on it, same wiring as the other plug.
    Which, since no one has corrected me, I assume is wired correctly. (?????)
    So, tomorrow I will check the continuity of the 0.5amp fuse.
    According to the manual, can be the remote cause of no action on the machine.
    Thanks,
    ~John
  10. #20
    Dec 2013
    476
    Sorry to confuse.
    Thanks,
    ~John
    I'm waiting for an update.
