Results 1 to 10 of 11
    May 2010
    denver
    9
    Default Millermatic M-100 gun not firing, replacement or repair?
    Hi guys, I dont post much but was hoping for some insight?
    I have a Passport Plus (now discontinued) w/ the M-100 gun. Ive put several spools of wire through and countless hours. Ive noticed lately the gun wont fire, meaning when I go to start my weld it wont spark or feed?
    I checked the ground cable connections and they look good. Are the M-100 guns prone to breaking or should I be concerned with the machine itself?
    Looks like they sell a replacement trigger, which is what I suspect this might be?
    Any suggestions on what I should be looking for?
    Also, if I do need to in fact get a new gun what are my options for my setup. NOTE: I do a lot of tight spaces welding, so a smaller nozzle is nice.
    Cheers,
    Nov 2012
    Northern Arizona
    542
    Pull the plug off from the machine and test for continuity through the trigger. Otherwise check the amphi connector at the machine for an good connection.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Dec 2010
    Andover, Ohio
    148
    Did you contact Miller?
    3,950
    Trigger wire off in gun...Bob
    May 2010
    denver
    9
    Thanks for the reply, I will check the continuity and gun connection.
    I have not contacted Miller, it looks like the warranty on this has expired. My machine is 3+ years old now.
    Any suggestions on what a good replacement gun would be. Keep in mind I would prefer a smaller nozzle design for tighter areas.
    Jul 2008
    Delhi, Ontario:
    1,997
    Quote Originally Posted by tarbellb View Post
    You might want to try a gun from Praxair ( Prostar ) .
    I've been buying them lately & I'm very impressed.
    I really like the fact I can turn the neck 360 degrees when welding out of position !
    They run from 150 amps. to 400 amps.
    Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    May 2010
    denver
    9
    So it turns out I have a M-10 gun, not the M-100. Red trigger.
    Is the M-100 a upgrade from the M-10? Should I jump to a Bernard or Prostar? Budget wise Id like to keep in near $150?
    3,950
    Its a new part number for the same gun...Bob
    Cave Creek Az
    1,051
    Just fix the gun and be done with it. You can often pull the trigger apart, then pull the micro switch apart and lightly sand the contact points. Otherwise a new trigger is about $20. Pull the connector at the welder and insert a bent paperclip into the terminals to jumper it and verify drive motor operation. Ohm out the trigger before you pull it all apart.
    Jul 2008
    Delhi, Ontario:
    1,997
    The Prostar guns I've bought , run about a dollar per amp. = 150 amp.... $150.
    Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
