Results 1 to 10 of 10
    May 2010
    Central CA
    784
    Default .045 to .035 chart
    Is there a chart to convert .045 to .035 ipm.
    I was welding up a receiver hitch for my pu. It has the 2 1/2'' receiver.
    I took out my iphone and went to the new Miller app, it said 29volts 390ipm .045.
    I did not have any .045, so I made the .035 work at 525 ipm, it was not quite enough, but worked.
    So is there a chart I could use to get ipm right the first time?
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Jul 2010
    Four Flags city
    304
    What material thickness?
    Cave Creek Az
    1,051
    You do realize that those voltages are well into spray arc territory, and you will need a spray arc blend, not just CO2, or 75/25?
    Jun 2009
    greenfield new hampshire
    884
    what charts reach into 29 volts
    May 2010
    Central CA
    784
    Default Answers
    Sorry, I've been working on my speedster and have not had time to reply, then my internet went down for 8 days.
    Big Mike, My first project was two 1X3 flat bars welded to a piece 2 1/2" SQ tube.
    For a double lip hitch, farm equip.
    Next was a equalizer hitch for my car trailer. Nobody makes the 2 1/2'' receivers mounts yet, all are just 2''.
    Mine was 2 1/2'' solid SQ stock welded to 2X2 1/2'' solid stock.
    To make a adjustable equalizer hitch.
    I drilled the holes and welded the 2x2 1/2 perpendictular to the receiver with a 5'' rise and 7'' drop.
    I beveled the 2 1/2 SQ and filed the V with weld and put a 2'' SQ tube cut at a 45* for a gusset.
    Walker, I sprayed with 98/02.
    Kevin, I used my Miller App on my iPhone to get 1/2'' steel (is as high as it goes)
    29-30 volts, 315 amps, 98/02.
    Still looking for a chart.
    Good Luck,
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
    Nov 2003
    3,572
    Thumbs up
    Here is an article from Welding Design that gives the raw data to calculate it..
    http://weldingdesign.com/welding-qa/...l-voltage-7806
    Hope this is helpful...
    BTW... how about posting some pics of your "Speedster Project"...??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    May 2010
    Central CA
    784
    H80N, Thanks for that page. That's a lot of ciphering just to do a little welding.
    What I got out that was a huge head ache and a heavy drinking problem.
    So I think you use 1.5 a factor and will be close.
    Like the App called for 390ipm of .045 times 1.5 factor equals 585ipm of .035 and would be a better choice than my guess of 525ipm.
    Thanks again,
    Turns out the heavy drinking is really no problem and the head ache went away.
    Good luck,
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
    Nov 2003
    3,572
    Smile
    and the Speedster pics..?? pls....
    My Blue Stuff:
    Jun 2009
    884
    Quote Originally Posted by Bob Miller View Post
    Good Luck,
    Bob
    thank you bob, i was just curious, my 252 only goes to 25 volts, or thats what i thought, made a mistake, it goes to 29.5. i recently purchased the 252, which is a great machine, i am not used to the setting numbers yet, my mm200 had 1 thru 6, low and hi for volts, just a matter of getting used to it. thanks again
    May 2010
    Central CA
    784
    The pictures are coming as soon as I can get someone to post them for me.
    Look for a whole new thread titled Speedster?
    Good Luck,
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
