Thread: Tig welding gas
    May 2006
    Kansas City Missouri
    84
    Default Tig welding gas
    Need to buy some shielding gas for my new tig welder. Call the local welding shop and the rep told me I could use CO2/Argon mix (the same gas mixture I use in my Mig welder). Is this true, the rep said he has never used a tig machine before, so I really had some doubts about his information. I need some advice on which gas to buy. The manual states Argon is the one for Aluminum, SS and mild steel. I will be practicing on mild steel and SS for right now, any help on the right gas would be appreciated....
    Jan 2006
    Albuquerque, NM
    1,788
    Quote Originally Posted by gearhead
    Like the "Manual" says, 100% argon is the gas you want to use for tig on SS, MS & aluminum.
    Regards, George
    Default Local "welding" shop
    You can also use a coat hanger in a pinch for stick welding, I'd find a different local resource for advice....
    British Columbia
    500
    Cool Gases
    Argon is the only gas you should be using allthough you can use heluim
    Sep 2006
    Maryville, IL
    75
    The manual states 100% Argon. Its that simple.
    Sep 2006
    Tampa, Fl.
    13
    Default Ur website
    Quote Originally Posted by JHCHOPPERS View Post
    Looks like I should have visited your place, I have been within spitting distance a million times!! Nice work on the bikes, wish I still lived in the area, would love to p[ick your brain!!
    Carefully
    The Mushroom
