Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Dec 2013
    476
    Default Wimpy torch on Dynasty 280 DX
    My new Dynasty 280 DX if I'm not mistaken is rated at 280 amp peak on AC or DC. The torch Miller supplies with their kit, and recommends if component, is the Weldcraft W280 Super Cool. I'm one of those nuts who reads manuals. It says 280 amps DC, 195 amps AC. I,m disappointed. Thicker aluminum will require all the heat I can muster. I'll be limited with a handicap of 85 amps.
    Do I now have to buy a heavier kit for heavy aluminum? What melts on these torches when I exceed rated amperage?
    I feel like I did years ago when i bought my first heavy duty truck. I wanted snow tires. The dealer (a small rural dealer) agreed to swap for snows for a fee. The tires he supplied were load range C, mine were load range E. His response was "You won't be carrying much weight, no problem." I went off the deep end! You mean I paid thousands extra for a heavy duty truck, hundreds extra for tires, and you want to limit me to half ton loads?
    What are other owners doing about this?
    Aug 2004
    Milan Michigan
    1,890
    Willie, That is why I didn't buy the package back when I bought my 300, I didn't want to settle on what the package supplies.
    I have a Speedway Torch SW320 and its the most flexible one Ive ever used verses what I used to have on a 250 synchrowave.
    There's nothing worse than having to fight with a stiff torch ( Not that yours is )
    But don't settle for a junk torch.
    Wa
    670
    You will only have issues if you plan to run at high amperage for an extended weld time. I doubt you will ever notice.
    Nov 2003
    3,828
    Quote Originally Posted by Willie B View Post
    Willie
    those ratings of 280 amps DC, 195 amps AC are at %100 duty cycle..
    so I do not believe you have anything to worry about...
    the torch has a higher duty cycle than the welder (see page 16 )
    http://www.millerwelds.com/om/o253086e_mil.pdf
    here is the torch data sheet..
    http://www.millerwelds.com/pdf/spec_sheets/AY30-0.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Dec 2013
    476
    I guess I'll cross the bridge when I come to it. I am curious how AC generates more heat than DC. Why the dual rating? As those of us welding only DC would likely opt for a Maxstar, and those of us wanting less than 200 amps AC would likely opt for a Dynasty 200, why recommend a 195 amp torch? I understood this torch had been developed expressly for the 280 because 250s weren't adequate. Have they underrated the torch to avoid warranty claims? I read the 280/195 amp ratings are contingent on pairing it with a Coolmate 4. It is Miller who paired it with a Coolmate 1.3! Miller is not the company I would have expected to behave in this way!
    Lake of the Ozarks MO
    3,596
    Willie
    Totally agree with this
    This torch is plenty for this machine
    Burn it up and you may be tripping the thermal on the welder!
    Miller knows what they are doing. Just not always cheap.
    A bigger torch is NOT comfortable to use btw.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Nov 2003
    3,828
    That torch has PLENTY of capacity for the Dynasty 280DX..
    just compare the duty cycle specs...
    Derating the torch for AC is normal because during the positive half of the cycle most of the heat is going into the tungsten and thus into the torch..
    During DCEN most of the heat is going into the workpiece....so it can carry more amps than it would for AC...
    My Blue Stuff:
    Dec 2013
    476
    OK then, good clean aluminum, you might run near 90% EN on heavy material, not so very much heat back at the torch. I realize I am probably overreacting. Welding in the range of 280 amps seems a very rare thing for me. I saw the Diversion 180 as a mistake for me to have bought, then I realize my new super welder that cost a staggering sum is severely limited by a torch, to a level only slightly greater than the Diversion! I've paid $600. for a torch who's manufacturer says won't do the job! Had I paired torch to welder I'd be crushed, filled with self loathing. When the manufacturer does it I say WTF?
    3,596
    Dude
    You are so not getting this!
    The duty cycle on the torch is higher than the duty cycle on the welder.
    I'm using nearly the same thing on my 700!
    This is how it has been forever. The torch on the Diversion is rated way less as well.
    All that being said, run the crap out of it! It's very doubtful you can feed enuff rod to even come close to duty cycle. It takes a LOT of very long and hot beads to do that. I would have that machine set on 280 more than one would think!
    You have a very nice awesome package there and once you have used it for awhile you will fully realize just how capable it really is
    Miller WC-115-A
    Miller Spectrum 300
    Dec 2013
    476
    Dude
    I'm sure that both of you are right. As Weldcraft is now Miller, I wish they had expressed it in a different way. Perhaps 195 amps at 100% duty, tapering to 10% at 280. I would be very comfortable with that. The notion of not to exceed 195 was shocking to me. I presume warranty will be void if I melt it.
    Has anyone melted one? What exactly fails? The size of the cable inside the water hose seems way too small, but a stream of water each pound absorbing perhaps 120 BTU will absorb heat. As I plead to my local power company over the last 45 years; if overhead cables were sized so they didn't produce so much heat, less energy would be wasted, you won't have to waste time trying to convince me that the wind blowing the heat away is the same as not generating it.Power quality would improve, less than perfect connections wouldn't burn off. Mrs. Jones would stop pestering her electrician about her computer misbehaving, and I would stop pestering employees of the power company about Mrs. Jones. You could build smaller power plants, less pollution, less global warming! Polar bears would be happy! Seal populations would be in natural balance. God would be in his heaven, and all would be right with the world! Best of all; power company employees would never have to listen to my speech again!
    I digress! Am I over dramatizing?
