Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 988 Bucket work
    Apr 2006
    TAXACHUSSETTS
    1,504
    Default 988 Bucket work
    Few pics of a bucket I,m working on lately.Side deflector to direct rock away from sidewalls.And a wear plate AR 500 12ft x4ft.Side deflector are 1/2"AR.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Aug 2004
    Milan Michigan
    1,881
    Looks like a fun job, Gotta be loving that crane.
    Wow, Ive never seen a mow board wore that bad before ( Now that's what I call a receding gum line ) I cant believe the teeth haven't fallen out.
    Apr 2006
    TAXACHUSSETTS
    1,504
    I,m going to be putting pc's in between those shanks.This is a 1979 machine and only has 4000hrs on it.When those teeth start snapping I will get the call to replace them.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    1,919
    Wow that's a big bucket. I'm kinda glad I don't get stuff that big. Looks like the cutting edge is radiused so the middle teeth stick out farther than the side ones. Never seen one like that. Looks like you're fitting it nicely, wouldn't expect anything else.
    Apr 2006
    TAXACHUSSETTS
    1,504
    Thanks MMW,That bucket is called a Spade bucket .This wear plate I welded with Dual Shield first time I have done this in the field.And I'm liking It.The deposition rate is awesome.I will be getting a tent setup together for doing this.Anyone got a good portable idea?Was thinking just a few 2x4,s cut with points and a couple of small tarps and spring clamps.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Lodi, CA
    1,315
    I always just used my welding blankets. Would hang them between the job and my truck (when I was still using the IHC) with bungee cords and visegrips.
    We usually call that a "vee" bucket out here. Common in rock pits and mines. Easier to dig into a pile or hard ground with a wide bucket.
    Wa
    661
    Quote Originally Posted by admweld View Post
    Pardon my ignorance, but I have never had the term "deposition rate" explained, would you be able to elaborate what you mean when you say you liked the dual shields higher deposition rate? Thanks.
    Lodi, CA
    1,315
    Disposition rate = pounds per hour. You will normally also see an efficiency rate, which translates into actual weld metal left after all flux is evaporated off during welding or knocked off as slag.
    Wa
    661
    I see, thank you for the response. A higher deposition wire or electrode would be a better choice if you have filling to do? Like a gap, or where material needs to be built up?
    Very nice work on the bucket Adam btw. How did you cut the radiuses into the front edge of the plate you are adding?
    Lodi, CA
    1,315
    No, a higher disposition rate simply means you can lay more work down faster, and in this case better, than any alternative methods.
