Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    PA
    365
    ok - here is another goofy project.
    My workshop (garage) is small so I have made do as best as I can.
    I used scaffold sections to give me adjustable long span shelves over the weld area.
    Ceiling is 10 ft high so I added a chain hoist off one end of the scaffold to move my plasma cutter
    off the top shelf when I need it.
    Problem is that the chain hoist hooks are 10" apart at the minimum so I can't lift high enough
    to put the plasma cutter on the top shelf.
    Decided to make a poor man's gantry crane using a section of garage roller track.
    I added 2 pieces of 2" x2" square tubing to span the scaffold frames much like planks.
    The roller track is attached to the front and back square tubing.
    The roller track can slide along the front 2x2 tubing. (Front detail photo)
    and it pivots at the back 2x2 tubing connection
    The key to the crane is a neat roller I salvaged from a Nordic track ski trainer.
    It slides on a 5/8" shaft and turns freely in one direction but locks on in the other direction.
    This gives me a "semi" chain hoist. Nylon strap is wrapped around the roller and I
    am able to move equipment up and down from the top shelf.
    The existing chain hoist is visible in one of the photos.
    I can get about 8" closer to the ceiling using this method.
  2. #22
    Jun 2008
    3
    Default Kayak roller
    Quote Originally Posted by Geoffm View Post
    I am going to liberate that kayak roller idea - that is brilliant and simple!
    Geoff
    My version of the kayak loading roller. A cheap job from offcuts and 2 suction cups, with a wooden roller made from a fence post
    The only problem is the curve of the windscreen means only the top 2 suction cups touch the windscreen - still works ok and doesn't move. Mark 2 would have the suction cups handle cut in half with a hinge joint so that it can articulate to follow the curve top to bottom.
  3. #23
    PA
    365
    Geoff,
    Very clever and well thought-out design !
    Hope you don't turn on the rear wiper when this is installed.
    Burnt
  4. #24
    Dec 2013
    At the epicenter of the Green Mountain Range in VT
    392
    Quote Originally Posted by Burnt hands View Post
    My sons did everything too young. I had a snowmobile when Seth was 10 with no reverse. He couldn't pull it in or out of the shed. I took 20' of door track, two rollers, an old come along, and a sling. He could lift it a few inches, spin it around backward, and push it in easily. It was thereby dry and ready to go next run.
  5. #25
    PA
    365
    ok - here is the latest goofy project just in time for cold weather.
    A neighbor tossed out a nice stainless bbq but it was huge and heavy which is why it stayed put for a day.
    Went home and got a hand truck and rolled it 1 block back to my house.
    Over the years, I have picked up several this way and found them to be a
    good source of stainless sheet metal and propane burners.
    Last year I found one at the curb and asked the neighbor if it was trash.
    He said "yes, please take it as I don't want to clean it. I'll buy a new one next season"
    Even came with a half tank of propane.
    The latest one looked good from the outside but the burners and grates were bad.
    All the sheet metal was good and non-magnetic unlike most of the ones I find.
    It also had a ceramic searing burner which I used to make this project.
    Used the stainless sheet metal for the body and reflector and some 3/4" and 1" ips stainless pipe for the support.
    So the old bbq came back as a nice directional heater.
    Please excuse the terrible sheet metal work.
    As usual, I could have saved lots of time and work by buying this one from
    Harbor Freight but what fun would that have been.
  6. #26
    PA
    365
    More photos of propane heater showing added reflector.
    Burner is 3" x 20" and uses about 3/4 lb of propane per hour.
  7. #27
    PA
    365
    Here is the February 2015 goofy project.
    Got a call from a caterer who got my name from my plumber friend and needed a special press made for a new sandwich he had in mind.
    Met him, got the details and made this gizmo.
    He buys shredded potatoes and wanted to press them into 3" x 6" x 1/2" to 3/4" thick hash browns..
    His special "sandwich" uses 2 of the hash brown bars like bread and he puts a slice of scrapple in the middle.
    He puts the scrapple in the press to make it the same size as the hash browns.
    The whole thing is then deep fried and served.
    I didn't ask for a calorie or fat count but it intrigued me.
    Just did the welding and didn't ask.
    Press is made from 1/4" thick 316 ss plate to make it easy to clean.
    Plus it was what I had on hand.
    Used my existing HF 1 ton arbor press to test the initial design concept.
    My arbor press was much too dirty for real production but he liked the concept and went ahead with it.
    He bought a new HF arbor press for his use.
    Seems like a lot of work but who knows - maybe he has something here.
    For a change, I got greenbacks for the work as opposed to the usual beer and pizza from my pals.
    And I thought I had too much time on my hands.
  8. #28
    Nov 2003
    3,506
    Thumbs up
    SCRAPPLE..... certainly places you in Pa.....
    never had it fried.... only as headcheese cold..
    Good Stuff...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  9. #29
    PA
    365
    Here is a version of March Madness.
    Friend has an undercounter sink which is molded into the countertop.
    Over the years the sink has cracked and pulled away from the countertop at 2 of the corners.
    Not repairable as it is not solid surface material but rather cheap laminate over particle board.
    So as usual, I saw the opportunity to do some cutting and tigging.
    Made a screw jack to take some of the weight off the weak edges.
    Simple solution would have been a couple blocks of wood and some shims.
    We'll see how long it is before the sink drops thru.
    Got paid with Guinness, corned beef and cabbage - life is good.
