Results 1 to 10 of 10
Thread: t-joint uphill
    Mar 2014
    5
    Default t-joint uphill
    Went to a interview, used 1/16 flux cored wire, gas shielded, uphill. What are the correct settings?
    Mar 2014
    27
    Default t-joint
    There are several things that need to be addressed here, who what where when and how kinda hard to dial it in with out certain info.
    I accidentally hit the friend request button, nothin personal.
    Oct 2009
    Northern ND
    17
    Little more info. would help. Type of wire, straight CO2, material thickness, joint prep, etc? Example would be 1/16" Triple 7, straight CO2. Good starting point would be 25V, 175in/min. See attached link.
    http://www.hobartbrothers.com/upload...ts/Triple7.pdf
    Mar 2014
    5
    3/8 thick, 25%argon ,Steel, 1/16 wire,vertical up, miller welder. T-joint
    Mar 2014
    27
    You should ok , I think oht is spot on, if anything, I think technique is gonna be crucial
    Mar 2014
    5
    Actually it was 75%-85% argon balance co2.. 125wfs 20-25 volts.. but I think wire type plays a big roll.
    Mar 2014
    27
    Dual shield?
    Jun 2009
    greenfield new hampshire
    889
    25 volts, yikkes, that is where i start for flat spray on half inch
    Mar 2014
    5
    Yes dual shield,
    Wfs125- 20-25 v
    175wfs 21-26v
    200wfs 22-27v
    225wfs 23-28v
    250wfs 24-29v
    300wfs 25-30v
    This is what my spec sheet says
    Ultracore 71A85 wire
    Mar 2014
    5
    What are the settings for uphill welding, what will you start @.. and ending? 3/8plate
Tags for this Thread
