Results 1 to 10 of 16
    Default bending back coupler?
    lent out trailer and now the bottom of the a frame coupler is scored and bent up a bit not allowing the tounge to fully seat. I was thinking some heat and a pry bar. What do you guys think?
    Apr 2013
    metro Detroit
    93
    I don't like to bend things back into place on a ball coupler. To me it's not worth it. I would replace it, even if it's a weld on. Just thinking of safety, if it came loose at 60mph..........
    this is true... yes it is welded.. i got a quote for 200 plus part to have a new one welded on .
    Aug 2004
    Milan Michigan
    1,863
    I work on trailers of all sorts and the one thing I never do, Is to try to repair a bent coupler, If that trailer comes loose from the tow vehicle and hits a family in a car coming the opposite way it could kill the whole family.
    Put a new one on.
    Aug 2004
    Milan Michigan
    1,863
    Don't listen to Frank, Replace the whole coupler, that way you know the parts are meant for that particular coupler frame.
    I've seen too many people jury rig stuff that don't end up working like they thought.
    Couplers are like brakes, You cannot afford for them not to work, Lives depend on it.
    Illinois
    643
    The coupler is what's between you and the trailer . Do you feel lucky ? REPLACE COMPLETE ASSEMBLY.
    3,954
    And between the trailer and other traffic if it comes loose. I have seen all sorts of jury rigs on coupler's in my years of trailer building...Bob
    Nov 2009
    western mass
    213
    Quote Originally Posted by fadetoblack188 View Post
    $200 plus coupler? ouch. that's more than $ 200 an hour. im sure most will agree me here. if it takes them an hour to do the whole job, that was with a coffee break in between.
    Nov 2012
    Northern Arizona
    554
    Why don't you weld one on? Pretty straightforward replacement.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Aug 2004
    Milan Michigan
    1,863
    Cayager, I agree, usually about a 45 min job. It should be $ 60.00 plus coupler, but then you need to figure 15 min. when they drop the trailer off and 15 min. when they pick it up, So a $ 100.00 labor plus the coupler.
    Elvis, Welding couplers on should be done by very competent welders, not a guy that uses a welder a couple times a year.
