Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Default arc gouging/air arc
    Hey I'm new around here and find it very helpful. I was wandering what size welder you recommend for arc gouging
    3,946
    Any big non inverter stick machine...Bob
    1,897
    Minimum 250 amp stick non inverter. These will handle 3/16" carbons which is about as small as you want to go. Not for heavy duty use though.
    Thanks. I appreciate the input. I have a bobcat 250 and some people say you can and others say you shouldn't so I was just wanting other opinions.
    Sep 2009
    Canada
    189
    250 amps minimum. Small carbons.
    500 amps preferably and larger carbons.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    1,897
    When gouging do not set the machine at 100% (wide open). Set it like 85% so it has some room to fluctuate while not going over max.
    Dec 2012
    Simcoe Ontario
    100
    A big rental one.
    Oswego IL
    743
    Default air arcing does not heart the machine!
    Would people stop pushing the idea that air arcing hurts machines, i have air arced off every machine i have owned, and i air arc a lot. Also as for bad for invertors, my maxtron 450 i had for 10 years, i ran about 150 boxes of 1/4 carbons through it, never had a probelm. Simply use the machine within its duty cycle and gouge away, what is the difference between 250 amps running large wire or an air arc electrode, other than cv vs cc current.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    Oswego IL
    743
    Default air arcing does not hurt the machine!
    Kevin
    XMT 304
    Miller Spectrum 625
    S22a
    Miller Legend 302
    Lincoln LN25
    Aug 2004
    Milan Michigan
    1,806
    Tryagn5, I totally agree with you, I'm trying to figure out why I'm not suppose to air arc off my 2001 Pipe Pro 304 or my Approximately 2003 XMT 304.
    I run 1/4" carbons at 350 amps on a regular basis, ( A couple times a month )
    without a problem.
    Just like Tryagn5 said keep it within your duty cycle.
