Results 1 to 8 of 8
Thread: Stainless frame
    1,883
    Default Stainless frame
    Picked up a new customer. I made them a stainless tube frame. All 1.5" square x 16ga tube with a brushed finish. No cleaning required on my end. They were happy with the result & have already ordered another. My phone doesn't take good close-ups so the weld photo is the best I can do.
    Aug 2009
    DFW
    35
    looks great! makes me want a tig machine!
    I wish my tig skills where up to that consistency. Nice work!
    Dec 2013
    349
    Looks great! Did you purge? I would love to see more about stainless, and the ways people address purging. I've seen a bit of the work they do at G.H. Grimm the maple equipment manufacturer. These guys recently were forced by buyers of equipment and company,(a new parent company bought them out), to weld instead of solder. There were some who doubted these guys could learn to weld so quickly. Their welds are flawless. They have machined aluminum backers for each joint to purge, and clamp, and suck out heat.
    For jobs where this is less practical I want to know how people solve the problem.
    Aug 2012
    Hermiston Oregon
    266
    Couldnt tell from the photo. Did you tig weld it. And what is it?
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    1,883
    All tigged, no purge. It is a cart frame that holds machine parts when they are servicing/cleaning a machine. My customer adds all their pcs./holders, wheels, etc. as well as blending all the exterior weld joints.
    Nov 2013
    Toronto
    46
    Nice job, was it hard to keep it all square, I always get warping and pulling when I tig 16ga SS tubing.
    1,883
    Keeping it square can be a pain. I keep measuring as I go to make sure it is staying. If it is getting out of square you can usually adjust which joints you are welding to help pull it back. I had one instance while half way through this that I put a ratchet strap from a top tube to the bottom tube opposite side & pulled it square while welding. When all done sometimes you need to push/pull to make it square.
    It can get out of square from the order you weld the joints & sometimes the tubes can be stressed from the mill & heat makes them move differently each time. Best advice I can give is to keep measuring & make adjustments on the go.
