Results 1 to 2 of 2
    Mar 2014
    Default Butt-Welded stainless rings
    Hi, I am planning a fire-pit project.
    I am looking for a commercially-available 304 stainless "butt-welded" ring, around 24" in diameter. I would like the material to be basically 1-1/2" flat bar, 1/8" thickness, formed into a ring and butt-welded.
    Does anyone know any suppliers that might carry something like this?
    Thanks,
    Keith
    1,907
    Any weld shop with a roller can do it. Post your location & I'm sure someone will give you a place. I'm in northern NJ & could do it.
    Edit -- I was assuming you needed it rolled the easy way? Or do you need it rolled the hard way? If the hard way you could also have it plasma cut out of sheet. I could do that also.
