Results 1 to 10 of 12
Thread: Chem-Sharp
    Oct 2003
    Santa Fe
    29
    Default Chem-Sharp
    HAWK or ???,
    Does anyone have an online source for Chem Sharp? BRWelder.com does not carry it and I have not seen it listed anywhere else.
    Hoping my Dynasty 200DX and Spectrum 625 get delivered tomorrow!
    Got the Optrel Satellite last week - WOW.
    Flat-out
    Feb 2006
    3,711
    Flat-out,
    Weld Shield Products: Chemical Sharpener for Tungsten Points
    KCI, Inc.
    po box 26614
    Charlotte, NC 28221
    704-372-8435
    Give them a call. I'm sure they can locate a dealer or sell direct.
    It's not the most popular stuff in the world and takes some trial and error to get it right. I pretty much use it for most applications on the Dynasty.
    The Dynasty has a short circuit protection built in. Extend your tungsten and inch or so beyond the cup. create your arc: "lift arc" or Hi Freq and when the tungsten turns cherry red dip the end(3/8") or less into the chemical sharpener. It will begin to burn hotter and start to point. Gently continue dipping the end in and out of the powder(chem sharp) and rotate it to achieve the desired point. If you stick the tungsten too deep, you will have nothing left. It's kinda like watching a racoon trying to wash a sugar cube. Too much washing and it's gone.
    Oct 2003
    Santa Fe
    29
    HAWK,
    Is this the same as
    this
    I emailed them to find an online or NM supplier.
    Flat-out
    Aug 2003
    Fl
    21
    Flat-0ut: how about checking this site:
    http://www.welding-direct.com/
    http://www.welding-direct.com/tigtorches.html
    It's on the bottom of the second link. Hope this helps,
    G.
    Sharpens Tungstens without Grinding, Splintering, Flat Spots or Ridges.
    Pointing Tungsten electrodes using the Tig torch as a heat source.
    Proceedure: Extend Tungsten stick out approx. 1" beyond the shield cup. Short out Tungsten against grounded work piece until it glows cherry red about 3/8" up from the tip. Quickly immerse the heated Tungsten approximately 1/4" deep into the powder, repeatedly, until the desired point is formed.
    5 oz. (142gr.) Jar contains enough for up to 500 sharpenings.
    DF600-6 Tungsten Pointing Powder
    DF600-6Sells Elsewhere For: USD $ 7.95WeldingDirect.com Warehouse Price:
    MSDS Sheet for Tungsten Pointing PowderA down-loadable file will be available soon.
    Feb 2006
    3,711
    Garcia,
    Thanks for the additional info and link.
    Oct 2003
    Santa Fe
    29
    Default Chem Sharp and BRWelder savings
    Garcia,
    Thanks. My local shop can get it for $10 (regularly $17) so I'll probably just do that. I've saved so much online that I DO want to spend some money locally occasionally. It wasn't clear to me which items weldingdirect.com didn't charge shipping for.
    All told I have have saved about $1800 off of list (about 30%)and taxes by going w/ BRWelder.com for my recent purchases. The only thing that hasn't arrived is the contractor's kit.
    Flat-out
    _______________________________________
    Dynasty 200 DX, Spectrum 625, AC/DC Thunderbolt
    F1 and WRC Fan
    Nov 2003
    3,690
    Flat-out
    congrats on the new equipment... you will get years of fun and productivity out of them... not to mention the "win new friends and amaze the neighbors" factor... you got a well rounded combination of good equipment...
    btw.. if the kit does not arrive in a timely fashion.. do not hesitate to email or call Bob at B&R he is a good guy but very busy in a small shop (is how the good prices happen)... and sometimes things do slip through the cracks...
    good luck
    Heiti
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2003
    Santa Fe
    29
    H80N,
    Thanks. You guys will be amazed, I think, when I send some pix of my house projects (months from now). Believe me, I have called bob many times to see if he had tracking numbers. Turns out he already shipped the last item (contractor's kit) and it will be here Monday.
    Flat-out
    F1 and WRC Fan
    Nov 2003
    3,690
    Had a chance to check out any of the surplus and scrap outlets in abq yet????
    My Blue Stuff:
    Oct 2003
    Santa Fe
    29
    H80N,
    No. Thanks for the advice and sorry for not responding. Much of that stuff will not work for my project, but I can definitely see it working for other stuff. I have checked out the LANL surplus and wasn't too impressed, but wasn't looking for stock at thge time either. I want to go to the ABQ places and see as well.
    Just in case Reliance in ABQ is too much $$, know of any good sources for 2x12 mild steel tubing (1/16, 1/8 1/4 wall) and SS all-thread?
    Would need to be shipped to SF, NM.
    Flat-out
    F1 and WRC Fan
