Results 1 to 2 of 2
    Mar 2014
    Exclamation lincoln pro core 125
    no spark at tip help
    asheville n.c.
    618
    Got wire feed? If so check ALL your connections inside machine. If those are ok, make sure your ground clamp connections are clean, then make sure your work is clean where you attach the ground.
