Results 11 to 16 of 16
    3,963
    Quote Originally Posted by DPSwelder View Post
    What brand of wire do u guys normally run?
    The shop i work in buys ESAB 710X in .045 and 1/16". I use Inweld .035 at my shop...Bob
    Oct 2013
    28
    Default dual shielded flux core wire
    I normally run lincoln outtershild 71m
    Jun 2009
    greenfield new hampshire
    889
    i run wire perpindicular, with about a 5 degree gun angle either way depending on the job, i have seen guys use so much of a push angle that the weld deposit just rolls out of the puddle in the form of round, steel balls
    Apr 2006
    TAXACHUSSETTS
    1,504
    I run Ultracore-71A85-1/16" dia
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Feb 2014
    5
    I just finished up certifying in dual shield for all positions (1F, 3F, 4F) at school. I took two separate tests, one for 3F and one for 4F. The 4F test covers all positions, but I did two tests anyways. I passed both tests on my first try. I used a slight drag angle (maybe 5 degrees at MOST) on overhead, and perpendicular on my uphill. These were all multi-pass tests with a root pass and two covers.
    The guys who kept failing were pushing their bead. The destructive tests clearly showed inclusions in their failures.
    Apr 2010
    5
    Default DUAL SHIELD II 80-Ni1H4
    I like DUAL SHIELD II 80-Ni1H4 Truck frames and structural steel. Ran every manufacturers version of Dual Shield with a lot passing X Ray inspections. If you drag under 15 or push and will not get perfect pictures. I haven't had anything but Triple 8 in my home wire feeders for 15 years. I got the Heavy Copper wound 125 handler when it first came out which is always loaded with solid core with .025 with CO2.
