Results 1 to 1 of 1
    S.W. Missouri
    155
    Default TB 302 Oil leak update
    Well finally got it torn down and found the culprit,almost missed it thinking it was the rear seal, was just going to pull the seal and replace it but decided to pull the cover for a look see.
    Cover gasket had slipped out of position, amazing it held for as long as it did.
    Thanks "duaneb55" for all the help.
    Trailblazer 302
    Lincoln SP-135-T
    Hobart Stickmate AC/DC
    Smith torch
    Spoolmatic 30A
