View Poll Results: Is your larger gas bottle for your MIG or your TIG?
Voters
8. You may not vote on this poll
  • MIG (75/25 or other mix)
    2 25.00%
  • TIG (100% argon)
    6 75.00%
Results 1 to 10 of 17
    Sep 2009
    WI
    22
    Default Larger bottle for TIG or MIG?
    I have been using a MM211 with 80CF 75/25 bottle for several years now. Works great and I'm about to try aluminum w/ the spoolgun soon so I need to get 100% argon bottle. I was thinking of getting a larger 120CF tank this time.
    However, I also plan to get a small TIG eventually (not sure on the diverson/syncrowave/dyna$ty debate yet). So once I get a TIG would you guess I will use the MIG or the TIG more often? Should the larger tank be for the 75/25 or for the 100% argon?
    I weld in spurts, sometimes I don't weld for a couple months, other times I weld every day for a few weeks, depending on the projects. Mostly automotive hobby projects, offroad 4x4 vehicles, drag racing, etc. Not sheetmetal work usually, more custom suspension and chassis work, etc.
    Just trying to plan ahead, Thank you.
    Nov 2009
    western mass
    208
    Default ??????
    Quote Originally Posted by folkenheath View Post
    not to be a jerk here but how the **** would we know what type of welding you would do more??? on the tank question. my feeling is if you dont need it to be portable, i get the biggest tank i can. better value. i think for a 300cf 75/25i pay around $70 . im sure a little dinky one would be at least half that price and you get a fraction of the product. just like anything in the world, the bigger you buy the better value. buy a grinding wheel pay $5 dollars. buy 200 at a time and get them for less than $2 dollars. but thats just me
    Feb 2013
    Canada
    103
    a have a baby c25 , a baby tri-mix , and a big straight argon,
    now ,
    -did you ever tigged before?
    why want a tig machine now?
    if you asked mean you havnt done tig much in your life...!?
    every person is different,and thats why there is so much different machines out there!
    every machine got theirs pros/cons
    no one can decide for you!
    2,908
    As mentioned we can't know which process you'll use more
    BUT Tig uses more gas because of Pre-Flow and Post Flow
    Most likely your supplier will swap out the gases if you find you need the 125 for C25 rather than Argon. You'll just lose the gas that was in the bottle when you exchange it before it is empty.
    Illinois
    612
    WISCONSIN ? Tha explains it . Kidding . Where you at in Wisconsin ? I get my cylinders from Advanced Welding near Greenfield , here's their craigs list post .
    http://milwaukee.craigslist.org/tld/4349192348.html
    If you look at their prices, there is not much price difference from a 80 to a 125
    I would go with a 125 or 150 for each.
    As stated tig will use more gas. The suppliers by me will not refill the 300 size big cylinders unless they are rented from them. 150's are the largest.
    Nov 2012
    Northern Arizona
    528
    I find that the 120/150 size is the best comprise between filling often and portability. I weld for fun not for work. I do take jobs on the side to help with the new equipment fund. If an 80 works for mig it will probably do for tig too. If you find you are filling to much then go bigger. It is also worth buying multiples of the same gas so when you run out on Saturday you can switch out and keep going.
    Really it all boils down to you... ya know?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Apr 2012
    Western Pa.
    266
    I buy the big ones myself it's the best value.
    My big Argon has a Y and I run one hose to mig and one to Tig michine. One big bottle 2- machines.
    Works for me.
    Nov 2009
    western mass
    208
    Quote Originally Posted by gnforge View Post
    Works for me.
    you mig weld with pure argon? or tig with 75/25?
    Jun 2009
    greenfield new hampshire
    881
    i bought a diversion 165, i dont do much tig work, after my little bottle ran out, i went back to airgas and did a 1 yr lease on an argon bottle. it sucks paying lease fee,s but the price of gas more than makes up for it. it cost about the same to fill the 375 cu. ft. leased bottle as it does to get a refill on those small knee high bottles
    2,908
    Quote Originally Posted by cayager View Post
    Mig Alooominum
