Results 1 to 8 of 8
    Wa
    671
    Default Advice needed for galvy mig welding
    Hi guys, I am about to have to do some welding on some galvanized steel studs, channel, angle, etc. All of it is thin, like 14g +/-. My question is this, in the past, every time I have encountered galvanized material, I would just strip the galvanizing with a multi flap then proceed as normal. With this job, that would be very time consuming and not very realistic. I will be using my millermatic 180. What do you guys suggest I do? Can I use my er70s-6 with 75/25 and have good results? Is there a different wire and or gas combo that is more appropriate that I could run with my machine? Do you have any other suggestions?
    I am aware of the hazardous fumes produced from galvanized welding, I will be in a well ventilated area with respirator. Thanks guys.
    Mar 2011
    st-eustache qc.canada
    262
    I had best results with grinding, sometime you can skip the grinding by stick welding it but on 14 ga. ???
    I doubt there is another way to properly do that.
    Wish you get more usefull answers than mine.
    Feb 2013
    Canada
    112
    Best advice i got-
    Stay away from it.....loll
    Phil
    Nov 2003
    3,846
    Smile Silicon Bronze MIG wire...
    Have you considered Silicon Bronze???
    it is becoming more popular in Automotive and HVAC applications...
    here is an interesting site..
    http://wisconsinwireworks.com/weld_galv_steel.html
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Wa
    671
    Thanks for the link. That stuff sounds like it's exactly what I need. No removal of the galvy required and no paint required for corrosion resistance. Anyone used silicon bronze wire in their mig?
    Apr 2012
    Ohio
    47
    70S-3 would be better than -6 because of lower Si content. Si does not help with Gal material. Be cheaper than bronze, although bronze is the best long-term / best results wire. Depends on if you will do more in the future etc... I would buy 70S-3 and see how it turns out for you.
    3,975
    I use it for thin un coated sheet metal like auto repair panels. It sucks for galvanized coatings and i like a good S-6 solid wire better. I was a union sheet metal worker in the 80's and welded a million miles of galv duct work, well seemed like a million...Bob
    Wa
    671
    Hey bob, what didn't you like about silicon bronze on galvanized material?
