Results 1 to 10 of 16
    asheville n.c.
    618
    Default solid core welding
    .035 75/25 gas, my boss says you can't weld that uphill. I say you can. Am I wrong
    Jan 2012
    Coos Bay Oregon
    22
    Well, he may not be able to, the rest of us can. Set powersource at 17-20 volts wfs 100-150 ipm. Use a Z or u pattern pausing at the toes to fill any undercut. Note: volts amps approx.
    Dec 2013
    435
    Quote Originally Posted by beamwalker View Post
    How else would you do it? or are you talking about thin sheet?
    Nov 2012
    Northern Arizona
    549
    I run er70s6 in that size and shielding vertical up. Works great. The inverted-V is effective. If you have never ran it uphill then find a little scrap to practice on first. It takes a bit to get it sometimes.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Aug 2004
    Milan Michigan
    1,834
    When it comes to vertical up you need to turn the heat down from what you would weld the same material at because your staying in the same area which gives you the heat for penetration, and like someone said in a earlier post, you need to pause at the outside edge to let it fill so you eliminate under cut.
    2,942
    Wa
    643
    I run less heat and wire, quick across the middle, pause on the edges so they fill. I have trouble with a "saggy" looking bead if I run too much wire, and or am not quick enough jumping to the other side.
    asheville n.c.
    618
    We made bumper for our crane, while he was gone I fooled around with it until I got it looking like I tig the weld. Didn't say a word, when he came by yesterday, inspecting was very happy with the appearance so I told him I ran it uphill, he told me to grind out and reweld, I refused
    Oklahoma
    730
    He is wrong.
    Griff
    Apr 2012
    Western Pa.
    307
    Your boss is wrong. Up hill is one of the safest welds in mig. Meaning it is easy if your not experienced to make a weld look good and not have proper penetration foremost downhill then flat. But it's almost impossible to weld up and not have good penetration. So if your vert up weld looks good your almost assured u have good fusion & strong weld. In my opinion as far as mig is concerned vert up is definitely doable (do it all the time) and a strong weld.
    Ps. I rarely ever weld mig down for any structural type weld or for any weld unless it's just for looks only, no strength required. It's vert up for me all the way.
