Results 1 to 8 of 8
Thread: fuel tank
    Aug 2013
    9
    Default fuel tank
    I'm going to fab a fuel tank for a small outboard engine. I am trying to find a weldable filler neck and cap. Cap needs to have a vent that can be shut off. Any suggestions on where to purchase.
    Also any tips on what kind of aluminum and filler would be best. I'm thinking of using 1/8" aluminum sheet.
    Salem ,Ohio
    3,936
    Cool
    Quote Originally Posted by Mtbj View Post
    If you can't find anything off the shelf give me a yell...Bob
    http://www.ebay.com/itm/Aluminum-Bil...-/321323884277 adding a vent/valve would be easy
    northern NJ
    1,890
    http://www.coyote-gear.com/aluminumfillers.html
    http://www.speedwaymotors.com/Filler...Neck,7539.html
    Why does the vent need to be shut off? It needs to vent for temperature changes when not used I thought.
    MM250
    RCCS-14
    Aug 2013
    9
    Default fuel tank
    It's a small outboard for a canoe. When it is removed for transport the vent must be closed so the fuel won't spill.
    Aug 2013
    9
    Default fuel tank
    I was thinking of using 5052 sheet with 5356 filler metal. Any suggestions?
    Salem ,Ohio
    3,936
    Cool
    I made some motorcycle tanks for my kids and his friends bikes and used 6061 because it was handy to find and work with..Bob
    northern NJ
    1,890
    I was always told to use 5052 for tanks. I don't have anything in technical data to back it up though.
    If you do close the vent don't leave it in the sun or an enclosed vehicle.
    MM250
    RCCS-14
    Mar 2014
    11
    aaMetalmaster,, your items are going to come in handy for me soon, I just ordered a G3 boat and am going to put a vented 10 or 12 gallon aluminum fuel tank in it up front to get the nose down. I saw several things that could come in handy. I will be in touch. Adam
    Don't underestimate how far acetone vapors can travel.
