Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jan 2014
    14
    Default let's talk about 6g smaw open root
    6g stick open root sked 80 2" dia.
    If anybody has any tips, tricks, suggestions, please do post here.
    Thx
    3,952
    Looks like a 1G...Bob
    Feb 2014
    20
    hard to tell but the gap looks to big
    Jan 2014
    14
    3/32 gap n land, what can I do to heighten bead size on ID of pipe , usually keep rod pointing at middle of pipe with occasional push at top, run bout 50 amps 3/32 rod
    Jan 2014
    14
    Hot pass n cap came quite easily,
    Just that root kinda slowing down progress
    Mar 2014
    27
    Default good root?
    What are your concerns
    Mar 2014
    27
    Quote Originally Posted by willy j:318552
    If I remember correctly, the root rein. Is a givin provided you wet in your root real good with good pen
    Jan 2014
    14
    I just wondering about any other techniques I could use to get the bead taller on inside of pipe to say 1/8 opposed to the 1/16 I'm stuck with right now, the reason I'm conceded is because I'm doing a test soon where 4 coupons are cut out and bent 180 deg. Root face 2 of each. Sometimes I'm getting slight undercut on my root bends, thus the question about taller wider beads
    Mar 2014
    27
    You are referring to the root rein on the inside of pipe?
    How long you been welding
    Mar 2014
    27
    Quote Originally Posted by willy j:318568
    well then if you have undercut I suggest that you should hold a little longer on the corners, there fore the slower speed along with just a whisker of a drag might help. Are there not any limitations on the root rein? Sometimes to much is unexeptable
