Results 11 to 20 of 21
Thread: Spoolmate 30A
    I guess I can't read. The original post states damaged wires- not 10 pin connector. If that was implied I stand corrected.
    Nov 2009
    western mass
    212
    ill guess here and assume hes trying to repair the cable somwhere in the middle of it with some sort of connector on each half. like maybe a weatherpack automotive type connector. if you go that route, they are on ebay and i think they go up to like 10 wire. personally i hate cobbled together crap and would replace the whole cable if need be. im sure it would look great with big connector somewhere in the middle. and as cruizer said and im sure is rolling on the floor laughing, i dont think their pushing 10- 20 amps through a cable thats about the next step up from telephone cord.
    Nov 2003
    3,633
    Unfortunately... too many times people get confused by the Names... 15A & 30A on those model Spoolmatics and somehow assume that the "A" stands for AMPS...
    Which it DOES NOT..... and it goes downhill from there... then the threads get sidetracked into all kinds of nonsensical rabbit holes..
    what the heck could you possibly weld with a 30 Amp or 15 Amp spoolgun...??
    Maybe the OP could post a picture or two of the damage to his 30A to help clear the confusion
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Jul 2006
    28
    Quote Originally Posted by cayager View Post
    Bingo that's what I'm looking to accomplish, I just want to repair the cable with a connecter. I don't want it to look like an abortion but I think a 5 pin connecter would look ok it sure is cheaper than buying the whole cable.
    By the way thank you all for your time and your advice I think I'll buy one of those water proof connecters off of Ebay.
    Mark
    8,281
    Unsure where the 5 pin connector comes into play either, cause you've got 3 wires for controller, 2 for trigger, 2 for motor and one for sense, the sense isn't used often, so you'd have 7 not 5. Never the less for these breaks, I'd either solder and shrink tube the wires or use heat shrink butt connectors for 18-20 gage. Freaking simple....
    Default Spoolmate 30A
    I'm with cruiser. Why bulk it up more than it needs to be. Solder n shrink and done.
    Nov 2003
    3,633
    The only thing I would ad is to suggest that you cut the whole cable so that all the strands end up being the same length when you strip back to undamaged strands and solder, splice & shrink.. it is going to end up a bit shorter anyway..
    Long ones and short ones are kind of nasty to look at..
    My Blue Stuff:
    Jul 2006
    28
    Well its been longer than 5 minutes ago since the last time I counted them last but I thought I counted 5 but you probably are right. Well I have shrink tube and solderless connecters and I originally thought about doing it that way but I saw these waterproof connecters and thought that might be a better way to go. I'll have to recount the wires and fall back and regroup and see what direction I want to go thanks all.
    Mark
    Aug 2008
    Orange, TX
    1,216
    Solder wires (no connectors) and heat shrink tube as cruiser and H80N have already suggested but when I do this I stagger the joints to avoid a large bulge in the cable and a larger diameter heat shrink tube over the whole mess to tidy it up.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    May 2010
    Central CA
    785
    Default 29a
    I agree with duane. I've done it both ways, and the staggered way is all most imperceptible.
    You might lose a foot of wire doing it that way.
    Just call it a 29A.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
